no fire b18a
Old Jan 22, 2014 | 04:26 PM
keslerbuilt's Avatar
Default no fire b18a
i have a b18a obd0 there isnt no fire, i own a junkyard but all the bseries distributors i have are obd1/2 i have plenty of d series ob0, could i use the 1/2 or could i take the igniter/coil out of the d series obd0 and put it in thr b series
Old Jan 22, 2014 | 07:56 PM
fcm's Avatar
fcm
Old Fart
Default Re: no fire b18a
Have you tested the coil or ICM, or are you just tossing parts at it to see if you can get it running?
That really only works when the problem is the first part you fling at it.
You own a junk yard, you must have access to parts catalogs, [ https://www.hondaautomotiveparts.com/ ] crossreferance the parts, if the numbers do not match it is a good bet the parts will not fit/work.94
Hiboost 2.0
Oct 3, 2013 09:04 PM
