00 Civic - Rear disc brake and IACV conversion questions!!!
Old Jan 22, 2014 | 01:08 PM
cuzismoked's Avatar
Default 00 Civic - Rear disc brake and IACV conversion questions!!!
hello! i dont know wich handbrake cable i have but it doesn'T fit and yes it is disc brake conversion the're like 1 inch shorter????i think its from a 95 civic hatch TRying a put this on a 4door 2000 civic
i also have an idle problem i guess its the IAC i have an manual b20b swap in a civic 2000 automatic. automatic is 3 wire and manual is 2 wire. do i need an manual engine wiring harness??
sorry for my bad english!
PLZ HELP ME !!!!
Old Jan 22, 2014 | 01:16 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Rear disc brake conversion!!!
You can re-pin your wire harness for 2 wire IAC. You'll need to use the B18/b20 auto computer.
You can lengthen your e brake adjuster so that integra/eg cables fit. It's located under the arm rest.
If you search, you'll find details on both.
Old Jan 22, 2014 | 01:26 PM
cuzismoked's Avatar
the car only run with the original auto computer i dont know why i have tryed odb1 chipped ecu, I also tryed manuel obd2a it start but not run... what u mean by re-pin my harness take off the 3rd wire??? i havnt tryed an manual obd2... or auto execpt the original one
Old Jan 22, 2014 | 01:45 PM
B serious's Avatar
The D16Y7 ECUs signal a 3 wire IAC.
Most other ECUs signal a 2 wire IAC. Try google searching 3 wire to 2 wire IAC.
You have to pin one of the IAC wires in a different location on the ECU connectors.
Old Jan 22, 2014 | 01:59 PM
cuzismoked's Avatar
alright thanks alot buddy!! and for the handbrake i can change the adjustment stud???
Old Jan 22, 2014 | 03:19 PM
B serious's Avatar
No problem. And yes. Turn the adjuster bolt as far back as possible. Then hook the cables up. Then tighten the cable to the proper tension.
Old Jan 22, 2014 | 03:45 PM
cuzismoked's Avatar
well its already on the limit and the wire at the galiper is tight i cant even put the ''bracket'' on or i wont be able to pin cable in the spring. i thought of weld another stud or get a longer adjustment stud?? if its changable anyway thanks for the tips ima try the IACV thing i hope it'll work hahah!!
Old Jan 22, 2014 | 03:49 PM
B serious's Avatar
Lol...if its coming down to welding....just buy the right cables. 99-00 civic si cables will work 100%
Old Jan 22, 2014 | 03:58 PM
tony_2018's Avatar
Fish Twig
Source the integra emergency brake cable. It should fit.
Old Jan 22, 2014 | 04:20 PM
B serious's Avatar
^no. Those are too short for 96-00 civics. I have used them by turning back the adjuster alllll the way and then wrestling them on. But...they're not a direct fit.
Old Jan 22, 2014 | 04:32 PM
cuzismoked's Avatar
ok so SI same year work i though it would be integra 4 doors. ill try that then
Old Jan 26, 2014 | 04:55 PM
cuzismoked's Avatar
B serious i have done the 3 to 2 wire conversion for the ica it still light up the check engine but my idle is right i have done the valve adjustement sounded like diesel hahah i was wondering what could happen if i run the stock ecu is it the right injection can i blow up my engine will a sir 99-00 would work??? or a chipped one cuz i cant chip mine
Old Jan 26, 2014 | 05:49 PM
tony_2018's Avatar
Fish Twig
Are you sure. I had my cousin swap everything over from an integra, not the lca though, and it didn't look short.
Old Feb 4, 2014 | 06:42 PM
cuzismoked's Avatar
hey i would like to know will SI brake line will fit??? USDM cuz i am looking for new braided line thanks!?!
Old Feb 5, 2014 | 03:18 AM
MoNETz's Avatar
use any dc2 94-98 handbrake cable direct fit
eghatch9295
23
Jul 11, 2014 10:27 PM
zuruk
Jun 15, 2010 09:40 AM
ej8ster96
17
Aug 27, 2009 05:06 AM
DrewMD
Jan 2, 2008 09:19 PM
JDMBOLONI
Oct 28, 2004 09:52 PM
