COMPLETE NSX caliper conversion for Integra/Civic (calipers / rotors / pads / etc.)
Old Jan 22, 2014 | 12:27 PM
BlueTeg's Avatar
Default COMPLETE NSX caliper conversion for Integra/Civic (calipers / rotors / pads / etc.)
This is everything that you will need to upgrade your 90-01 Integra, 99-00 Si, or 92-00 ABS civic knuckles with larger, dual piston NSX calipers and larger 11" rotors. This is a complete kit. No goofing around with shaving brackets down or guessing which calipers will work with which bracket and/or rotors. This upgrade will clear 15" oem Honda/Acura wheels and most all aftermarket 15" wheels on the barrel and spoke side.
NSX front brake calipers (91-96 spec)
* dual / tapered pistons (40mm and 36mm)
* gloss black with silver "N S X" lettering
* 25T brackets
$450 (FIRM) shipped for just the calipers
Or for $550, you get the NSX calipers plus the rotors, race pads, and stainless steel brake lines listed below:
Mini Cooper 11" rotors
* eliminates the need for the 4 lug guys to have to run rotor spacers to center redrilled Prelude or ITR rotors
* eliminates the need to machine 3mm off of the caliper bracket to center Prelude/ITR rotors within the caliper. If the bracket is not machined completely equal on both sides, you run the risk of brake shudder from the caliper being misaligned resulting in brake shudder.
* lightly used for 6 track events
Hawk DTC60 brake pads
* ITR/NSX/S2000/Legend fitment
* these are race pads, not recommended for daily driving due to noise and dust they generate
Goodridge stainless steel brake lines
* great way to firm up the feel of the brake pedal if you're currently using the rubber OEM lines
Advantages of running the NSX calipers over other OEM big brake upgrades:
The NSX calipers have 2, tapered, pistons to squeeze the pads for superior brake modulation and brake pad wear characteristics.
The NSX calipers also have the cooling fins which help further dissipate heat from the calipers
....and of course, they don't have the " N S X " cast into the caliper for style points.
Old Jan 24, 2014 | 08:28 AM
BlueTeg's Avatar
Default Re: COMPLETE NSX caliper conversion for Integra/Civic (calipers / rotors / pads / etc
TGIF
Old Jan 25, 2014 | 08:25 AM
BlueTeg's Avatar
NSXy
Old Jan 25, 2014 | 09:23 PM
Reddead88's Avatar
Bumppppppppppppp!!M
Old Jan 26, 2014 | 11:42 PM
BlueTeg's Avatar
thanks dude
Old Jan 27, 2014 | 03:25 PM
EFSedan#6's Avatar
Just curious, but will this setup clear M7's with 4x100-4x114.3 adapter spacer??
Old Jan 27, 2014 | 08:35 PM
BlueTeg's Avatar
I have no idea.
Do you know if they clear ITR calipers? If so, then probably yes.
Old Jan 28, 2014 | 12:23 PM
BlueTeg's Avatar
ttt
Old Jan 28, 2014 | 08:38 PM
BlueTeg's Avatar
Old Jan 29, 2014 | 05:08 AM
Devon M's Avatar
$550 is a good deal for all of that. Nice!
Old Jan 29, 2014 | 08:53 AM
EFSedan#6's Avatar
Originally Posted by BlueTeg
I have no idea.
I dont know. I will ask on the Mugen forum. Be back soon.
Old Jan 31, 2014 | 02:51 PM
BlueTeg's Avatar
TGIF! ttt
Old Feb 7, 2014 | 04:00 PM
wutthebun's Avatar
nice price, & yes these will clear 15inch M7's
Old Feb 7, 2014 | 04:14 PM
olddohc's Avatar
Nice write-up. I dont need em but you gave such a good description i almost did lol.
nightscream
Apr 22, 2012 11:17 AM
Mattcuzko
Suspension & Brakes
Nov 15, 2011 06:43 PM
BlueIntegraBoy
Dec 23, 2010 05:28 AM
dr_latino999
Suspension & Brakes
Mar 15, 2010 05:59 AM
Darkteg
Jan 10, 2006 02:34 AM
