EF won't crank
Old Jan 21, 2014 | 07:48 AM
Nerdskateful's Avatar
Default EF won't crank
My Ef wont start. I've checked at grounds, fuses in car and out, also battery,starter and alternator are good. Main relay is good cause I can pop the clutch and fuel pump primes. Any ideas? Thank you
Old Jan 21, 2014 | 08:21 AM
4drEF's Avatar
Keyboard Humorist
Default Re: EF won't crank
Will it crank when you touch battery power directly to the solenoid on the starter?
What voltage do you read on the starter solenoid wire when you turn the key?
Old Jan 21, 2014 | 10:07 AM
I don't have a voltage meter and haven't tried touching the solenoid yet
Old Jan 21, 2014 | 03:58 PM
I touched the solenoid with the a from the battery and turned the starter. So maybe a bad ignition?
Old Jan 21, 2014 | 05:15 PM
instrument's Avatar
that or the clutch relay switch... jump the switch and try to start it.
Old Jan 21, 2014 | 05:48 PM
My ef starts with out having the clutch down
Old Jan 22, 2014 | 09:54 AM
Got a another ignition but the same thing car doesn't want to start.
Old Jan 22, 2014 | 10:23 AM
4drEF's Avatar
Keyboard Humorist
Get a multimeter and test for voltage
Old Jan 22, 2014 | 03:32 PM
Solved it was some random wires that the previous owner cut just grounded one and bypassed the other. Must of happened when I swapped dashes. Thanks for the help though
Timandsollin
Jul 20, 2017 04:35 PM
ethos909
17
Aug 24, 2013 11:09 AM
riosEF9
May 16, 2013 08:42 PM
apm
10
Mar 30, 2013 08:57 PM
vulcandan
12
Aug 11, 2003 03:37 PM
