No spark after running on 3 cyl
Old Jan 20, 2014 | 06:29 PM
ZombiePharoh's Avatar
Icon2 No spark after running on 3 cyl
I pressure washed my bay of my b18c and noticed there was water in the cyl 1 spark plug hole. With the engine OFF I removed all the wires to inspect for water. there was about an inch in cyl 1. I replaced the other wires to their homes and proceeded to clean the water out of the hole with a rag and screw driver.
there was a little bit left I couldn't get, and my old man suggest I just run the engine and let the water evaporate. When I fired it up it ran for about 45 seconds and died.
The wire was arching off the valve cover a few times so I moved it, it might have crossed another wire.
after then getting all the water dried up by hand I tried to crank my car over. No Spark. On any cylinder.
After inspecting the inside of the distributor cap I noticed there was quite a bit of dust and marks like it was arching everywhere, the rotor was kinda marked up as well.
Could I have fried my ignition coil? Any one have input thanks. I'm really stressed out.
It's an EJ8 with a B18C swap. ITR ECU.
Old Jan 20, 2014 | 06:33 PM
jcivicek4's Avatar
Default Re: No spark after running on 3 cyl
sounds like the ignition coil is gone dude
Old Jan 20, 2014 | 06:42 PM
Okay that's what I'm thinking too easy fix. I feel like such a jackass....
Could have been easily prevented. I learn the hard way always.
Old Jan 20, 2014 | 06:46 PM
CaliforniaSnow's Avatar
"After inspecting the inside of the distributor cap I noticed there was quite a bit of dust and marks like it was arching everywhere, the rotor was kinda marked up as well. "
It sounds like you probably ought to replace the cap and rotor while you're at it.
Old Jan 20, 2014 | 06:47 PM
Yes I plan on it.
ZombiePharoh
Jan 20, 2014 09:28 PM
v8killaz
Feb 26, 2011 03:40 PM
RockLee`
16
Sep 3, 2006 04:34 PM
SimbaDogg
Jan 3, 2004 02:57 PM
wuhungsixxx
Jul 16, 2001 02:43 PM
