Factory Alarm.Anyone sucessfully removed one?
Old Jan 20, 2014 | 11:46 AM
EscCtrl's Avatar
Icon2 Factory Alarm.Anyone sucessfully removed one?
My car came with a factory alarm.Something has went wrong with it and now the light relay goes crazy when I turn the key on.Everything works but the relay constantly clicks.I have looked at the wiring and if I just unplug things,it may disable my turn signals,hazard lights,and prevent the car from starting.Swapping relays doesn't solve the problem.
Old Jan 20, 2014 | 01:22 PM
djkurious's Avatar
Year?
Old Jan 20, 2014 | 01:25 PM
lazlong's Avatar
Default Re: Factory Alarm.Anyone sucessfully removed one?
Originally Posted by djkurious
Year?
"1992 Honda Accord EX CB7 F22A6 Engine H2U5 Trans"
Old Jan 20, 2014 | 01:32 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Have you tried just unplugging and leaving the security flasher relay out?
If that doesn't work, at the security control unit located under the driver's seat, you can try cutting the Red/Blk wire at pin 6 of unit. The Red/Blk wire feeds the ground signal to the security flasher relay to energize that relay.
Old Jan 20, 2014 | 02:02 PM
EscCtrl's Avatar
Year?
Lazlong got it from my sig line.
Thanks,I will try that.I have the entire dash out replace a wiring harness someone butchered to put in a Clifford alarm and aftermarket stereo.I also need to replace the blower motor or resistor.I have a separate post on that.
mechanix619
Audio / Security / Video
24
Aug 8, 2012 02:57 PM
HiProfile
Aug 27, 2009 10:06 AM
raceACCORDingly
Jan 16, 2007 06:04 PM
sony224422
30
Jan 8, 2007 01:13 PM
