MO: complete gsr head/intake manifold $400.00obo
I am trying to clean out my garage of stuff that I don't need. I have a nearly complete head from a 1997 integra GSR. It will come with everything pictured, head, intake manifold, valve cover, vtec solenoid, inner and outer timing belt cover, ect. It basically comes with everything except cams and distributor. The only issues to be aware of is one of the cam caps studs is missing and the threads are close to being stripped as pictured. I would also recommend replacing the valve stem seals due to some oil seepage on the intake valves. Lastly the plug is missing from the VTEC solenoid.
I'm looking for 300.00obo plus shipping.
As stated I would put valve seals in it If I were going to run it. The intake manifold is not missing anything unless you mean the throttle body or fuel injectors/rail. The butterflies, actuator, solenoid ect are all intact. This came off a running car.
cruizinmax
Mar 14, 2014 03:35 PM
HybridKOOP
Jan 21, 2004 04:52 AM
