Is this bad? Rusted metal frame under dash
I popped off the side molding from the dash board and I see a lot what looks like surface rust doesn't look to be bad but I am worried it can turn out to be a problem. My question is, is this bad enough to warrant taking the whole dash off and checking underneath? Should I clean it off and if so how would I go about cleaning it, a wire brush? Is there some type of coating I should put on it after I clean it off to prevent it from happening again? It was caused by the car leaking I believe but that has since been fixed and shouldn't be a problem.
I don't know, that does look pretty bad.
Look through the hole in the panel and you can see it goes on behind it too!
I would at very least, OSPHO it to convert the rust (iron oxide) to iron sulphate.
Maybe 3M rust defender?
What does everybody else think?
well, yeah it happens to all of the hondas...however, i DO use converter and a sealer on any exposed parts when i do work in that area, just for peace of mind.
jeff716a
Honda Civic (2006 - 2015)
15
Jan 30, 2007 02:21 AM
Will Albers
Mar 16, 2004 10:08 AM
