em1 window regulator
BEFORE ANYONE MAKES THE SUGGESTION lol, I HAVE ALREADY BOUGHT A NEW RUN CHANNEL FROM HONDA. The window keeps spacing near the top as it goes up. it rolls down PERFECT. but once its going up and it gets near the top the glass spaces itself from the run channel then goes back into place bending a small piece of the run channel back. its as if the bar at the bottom of the regulator where the white wheels slide on is bent. has anyone had this problem and was able to fix it?? do i need a new oem regulator??
theres the large holes to put the bolts in then it slides over to the smaller side in which they have been bolted to and tightened. i can post a pic of what the window does as it goes up. ill have to post pics tom of what the regulator looks like while its down.
Also do the glass adjustment procedure for 2D/3D in the diagrams I posted.
If none of what I mentioned helps, then replace the window regulator. The weakness of the regulator is the rivet hinge in the scissor joint.
ed1le
Apr 28, 2013 04:51 PM
willhitch26
Oct 25, 2010 02:42 PM
WhiteOnRice
Mar 8, 2007 03:32 PM
