99 civic cluster not working!! help!
Hello guys,
i hope you can help me with this.
i have a 99 civic coupe which the cluster magically stop working,
i replaced the speed sensor(which wasn't bad) , checked all power , checked all grounds, checked all the fuses and relays, with no clue of what it is. but i getting power.
cluster lights are working, the only signal i have is the battery(when i put it on ignition)
none of the gauges are working NONE.
but my headlights are working , even the wipers switch is working.
please help i have no clue of what is causing that i will appreciate !!!
thank you!
thank you!
Double check this fuse under your dash:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/civic-del-sol-fuse-panel-printable-copies-fuse-diagrams-here-1966666/
jeremyrocksursox
14
May 27, 2009 10:05 AM
HH814
Jun 3, 2003 01:51 PM
