duplicolor paint shop clear coat
so i was trying to figure out the cheaper way to do the base and clear and decided to give the duplicolor cans a try on small pieces. did a trim piece with rattle can base and rattle can clear came out ok
thought i would give the duplicolor paint shop clear a try.
mixed it with some reducer like i always do with clear coat for painting
did about 4 coats of clear on each panel.
after few hours of drying the clear from rattle can looks better than clear from spray gun.
i have hvlp gun set up according to instructions on the can
i warmed up the paint and warmed up the panels with a heat gun both times temperature was about same
top is spray gun bottom is rattle can clear.
I thought those Duplicolor paints were all ready to spray out of the can? If you added more reducer to it it may have flashed off too fast or started to lift the basecoat.
Try a slow thinner too, it will allow it more time to flow out as that clear is ment for small panal repairs and sets up pretty quick.. Its still junk I would reather use PPG clears any day.
You can get cheap clears from like eastwood or get some quality dupont clear from a paint shop. Those little cans are like 40-50 bucks a can, you can get a gal of clear from like napa for 90-100.
A cheap but better solution would be single stage kits from Eastwood/nason/ppg. If your not going for baller show car status and are content with a oem-ish finish these would be a better choice and the quality vs duplicolor is much better. I did nason single stage on my front bumper for my integra as a temp and even though the silver didn't match my chromobase (Silverstone metallic) it was pretty damn durable
Any oem color you like is more then likely offered in a single stage from better companies such as nason, ppg etc whatever your local auto paint store carries. Tri coat paints though are not offered in single stages
drumminforev
16
Feb 19, 2023 09:18 PM
drumminforev
Dec 8, 2006 10:10 AM
