Southeast Alabama, Florida, Georgia, Mississippi, South Carolina
Wake up Alabama!
Old Jan 17, 2014 | 04:02 PM
HYREV2NR's Avatar
Default Wake up Alabama!
What happened to all the Dixie peeps? This state's been dead forever in the Honda world. Spring isn't that far off. Crickets........
Old Feb 26, 2014 | 03:38 PM
92egls's Avatar
Default Re: Wake up Alabama!
Im checking back in...been out of it for a while . Last car I had was a 92 eg cx that had a b18b1 swap, si transmission , 450cc injectors, chipped p75 on 10psi. Was a fun car but eventually sold it to a friend of mine. I just recently picked up a 93 hatch shell from my brother. It needs a heater core and the dash put back in and interior pieces found and put back in. Has no motor, trans, mounts, engine harness etc so all of this has to be gotten. It needs a lot of work but ive got a good jump on it so far. Ive already got a d16z6 block that ive already got srp pistons, eagle rods, golden eagle head studs, cometic hg, act clutch already. A friend had all this in his garage and hadn't decided want he wanted to do so I bought it all from him. Next im ordering new acl race bearings, new rings, new oil pump, new timing belt and water pump set, and a gasket set. Debating on replacing the valve stem seals, and the springs and retainers in the head for brian crower while im at it. Going to be doing a 57 trim turbo on this as well before it hits the road just gotta decide how im going to run the setup and what injectors, FMIC, etc. Its a start I guess but its nice to have another hatch and cant wait to finish it.
Old Mar 10, 2014 | 01:39 PM
HYREV2NR's Avatar
Wow I can't believe someone finally posted here lol. Nice to see some better weather coming back for a change. I got spring fever now and ready to turn some wrenches.
Old Mar 10, 2014 | 03:29 PM
92egls's Avatar
lol yea im glad the weather is starting to change for the better. I worked on the car a little this weekend putting a new heater core in it. Running wire harness back through the firewall on the passenger side, and putting the blower motor and such back in so I could reinstall the dash. Still a long ways to go with it but its moving atleast.
Old Mar 12, 2014 | 12:27 PM
HYREV2NR's Avatar
Maybe I can get something/anything done if I can get rid of a headache I've had for nearly a week! The changing of seasons along with the barometric pressure doing a roller coaster ride from day to day is annoying but what do you expect from stupid Alabama weather?!
Old Nov 25, 2014 | 07:33 AM
92egls's Avatar
Update on the car as ive been busy and such so ive been going slowly at it and hardly working on it right now.
as stated Ive already got a d16z6 block that ive already got srp pistons , eagle rods, golden eagle head studs, cometic hg, act clutch already. Block has been notched for rods, head and block going to machine shop next week to be finished, new oil pump, new timing set, new water pump, complete gasket set, ex transmission, new radiator, new rod and main bearings, complete full exhaust ::new:: , and a few other odds and ends.
Old Dec 25, 2014 | 09:01 PM
blackoutt's Avatar
Old Feb 2, 2015 | 03:34 PM
HYREV2NR's Avatar
Bump for the heck of it.
Old Mar 16, 2015 | 08:31 AM
92egls's Avatar
ok another update on my 93 hatch with the d16z6 im building.
build is as follows at the moment...d16z6 bored to 75.25, srp 9.5:1 PM6 pistons ::comes out to 10.6:1 CR::, eagle rods, block notched for rods, block decked .010, milled .010, new stock valves, comp cams 012-16 valve springs, brian crower chromoly steel retainers, eagle head studs, 4 puck act clutch and pressure plate....and of course all new gaskets and bearings throughout....
Old Mar 28, 2015 | 08:37 AM
DiRT!'s Avatar
Old Mar 28, 2015 | 08:50 AM
92egls's Avatar
Old Mar 28, 2015 | 08:51 AM
92egls's Avatar
just picked up a set of 15x7 rota rb +30 offset for my hatch for 250.00
Old Mar 31, 2015 | 01:49 PM
92egls's Avatar
Picture of the hatch I am working on....Put the rotas on to see where the wheels would set since it has a 30mm offset and a 225/45 on them right now...ill probably go to a 205/50 soon
Old Apr 10, 2015 | 06:09 PM
blackoutt's Avatar
Old Apr 20, 2015 | 12:37 PM
92egls's Avatar
update on the car...As of Saturday it is running and no issues at all other than losing the stupid linkage pin and having to get another. Hoping Friday when im off work I can put it in and actually having time to drive it around for a bit and get to enjoy it.
Old Apr 27, 2015 | 02:39 AM
92egls's Avatar
My hatch
Old Jul 14, 2015 | 09:40 AM
oldschoolmaster's Avatar
Everybody in irvington al has hondas
I got a 92 grn gsr with type r swap
92 gsr red with built b17
90 civic truck
89 civic wagon lsvtec
95 civic ex coupe stock
roll tide
Old Jul 16, 2015 | 11:29 AM
92egls's Avatar
Well update on my sohc car....started getting everything up for the turbo kit for it....already got the new 3 bar map sensor on, 550cc rc engineering saturated injectors, and piecing together the turbo stuff now....aiming for 300-325whp
Old Aug 3, 2015 | 01:59 PM
92egls's Avatar
well update on the car got everything in and installed and just waiting on my buddy with my ecu and his laptop to start tuning it.
Old Aug 16, 2015 | 05:56 AM
HYREV2NR's Avatar
Wow, glad to see this thread alive and kicking again.
Old Aug 24, 2015 | 08:01 PM
1SiC 3DR's Avatar
I remember the Alabama section carrying on for days, new threads every hour, and then STANCE happened............
StuckInTexas
Aug 5, 2014 08:06 AM
sauceja
May 8, 2007 07:33 PM
EJ1 wilcox
Jun 18, 2005 08:19 AM
lucas569
Aug 17, 2002 09:59 AM
