civic ex 94 bogs and die when press the gas
Hi guys, Yesterday my car start to misfire in cylinder one, first put a new plug, still the same(the other was black), Measure the wire 6.58@ 20kohm's, this looks fine so I replace the coil and nothing. The cap and rotor are brand new OEM one month.
The distributor is new but it's a eBay king special. If I put the plug like half inch from the valve cover bolt the spark is completely orange.
A bad ICM can cause poor spark and affect more the most far plug?
Have you compression tested the cylinders?
Yes sir, 4 brand new Bkr7E-11 @ .025
The wires NGK he64 Two years, My voltmeter after 20k only have 2000 and 200.
Compression tested fine 195psi (9.0:1). In my tester this engine always be in the 195-200 range since day one.
forgot to mention the misfire randomly disappear and idle fine for a few seconds then misfire again.
ok, so I went out and swap the distributor the car still do the same, but when I attach the timing light to set the distributor. I realize that the rpm's in the gun at idle come and goes, if a rev the car a little the rpm's read solid.
This is a bad wire or braking in the distributor?
white_ej6
Feb 4, 2010 08:19 PM
StreetRiot_DRE
25
Dec 10, 2007 07:19 PM
Insane Beast
18
Apr 21, 2007 06:34 AM
