Heater/ Electrical issue!
Old Jan 15, 2014 | 01:22 PM
slammed1.8's Avatar
Default Heater/ Electrical issue!
Hey H-T
Ever since i took apart my interior to paint the inside the car. Ive had really weak heat from the blower motor (4 feels like 1) and none of the options like switching the channels for the heat work.... could someone gimme a few leads.... been stuck trying to figure this one out, and really sucks in this winter weather... Thanks!
Old Jan 15, 2014 | 11:30 PM
slammed1.8's Avatar
Default Re: Heater/ Electrical issue!
Bump
Old Jan 17, 2014 | 06:50 AM
slammed1.8's Avatar
Anyone??
Old Jan 17, 2014 | 09:21 AM
axis11's Avatar
Originally Posted by slammed1.8
Hey H-T
Ive had really weak heat from the blower motor (4 feels like 1) sucks in this
Do you mean the blower doesn't spin fast on #4? or only the heat is same for #1 to 4? Check the heater control valve. For the mode control not functioning, check your fuse.
Old Jan 17, 2014 | 12:03 PM
hacker4991's Avatar
I would probably check under neath the dash, see if any cables are lose or check the blower motor itself
Old Jan 19, 2014 | 01:50 PM
slammed1.8's Avatar
Thanks ill try these out and let you guys know what it was.
Old Jan 19, 2014 | 03:10 PM
FabricGATOR's Avatar
If you remove the glove box, it should be pretty easy for you because you probably have a lot of experience, you should be able to look at the connections and servo's.
That's what I would do.
Keep us posted!
Old Jan 20, 2014 | 06:46 AM
Former User's Avatar
You must provided car information in technical forums.
deerman2701
Feb 12, 2011 06:54 AM
Bangher4$
Honda Civic (2001 - 2005)
11
May 22, 2009 01:25 PM
ED6JDM
Oct 15, 2006 06:45 PM
cb1999nj
May 1, 2005 11:24 AM
Ransom
Jun 25, 2004 03:12 PM
