Suspension & Brakes Theory, alignment, spring rates....
Sway bars that fit on civic dx models?
Old Jan 14, 2014 | 11:23 PM
purplehaze707's Avatar
Default Sway bars that fit on civic dx models?
Hey whats up honda-tech i just put new struts and springs on my car and feel its time to install some sway bars for a little less body roll.
Now my question is can anyone point me in the direction of where to find sway bars that were made to fit civic models that never came with a factory sway bar in the front or rear?
Ive gone through forums and i found out suspension techniques makes a kit but i cannot find it anywhere online and eibach used to make a kit for the dx but its discontinued.
This is what im talking about http://www.civic-eg.com/viewtopic.ph...er=asc&start=0 , any help you guys could offer would be greatly appreciated thanks.
Old Jan 15, 2014 | 02:44 AM
hondamark35's Avatar
Default Re: Sway bars that fit on civic dx models?
it would be helpfull to know what year DX Civic you're refering to. you could also try searching. you may find more info that way.
Old Jan 15, 2014 | 03:17 AM
Sccacivic1997's Avatar
Go on eBay and type in sway bar civic and you'll get plenty
Old Jan 15, 2014 | 07:50 AM
Reyes's Avatar
If your car did not come with an OEM sway bar, then you would need the brackets from a model that did.
EXAMPLE: 96-00 civic would use brackets from a 99-00 Si.
OR you can get a sub-frame brace and use a generic style bushing/bracket.
Old Jan 15, 2014 | 10:50 AM
oh sorry, the car is a 1993 eh2 hatchback.
And i did look around on d-series.org civic-eg.com and on here and i found some threads on the subject but i cant find out where to get them or if anyone still makes the sway bars that fit on dx control arms.
Old Jan 15, 2014 | 12:50 PM
egsleepercivic's Avatar
get 94-01 integra non type r rear LCA, then you can use factory sway bars from the teg, civic or del sol, you can use the type r sway bar but you will need some form of sub frame reinforcement
for the front you can do the same, get lca from a 94-01 teg or 92-95 civic ex/si had the mounts for the front then pick the factory bar you want
imo the factory stuff fits way better than any of the aftermarket setups
Old Jan 16, 2014 | 05:12 AM
kyden's Avatar
not sure how one can not find things with google nowadays..
http://www.stsuspensions.com/product...ar-set-31.html
Old Jan 25, 2014 | 12:53 PM
bayFERIOroan's Avatar
I got a 14mm bar from a 98 ls I think? well its the 14mm one and I got the lcas with the sway bar and all hardware for 20 bucks. while its not a big bar that and the poly bushings in the rear control arms made a huge difference compared to worn bushings and no sway bar at all. just remember if you get a bigger one youll need something to brace the subframe with so you don't get any tear out, ive read of that happening
91EF919
Sep 1, 2008 07:50 AM
Nfire247
Feb 1, 2008 04:26 PM
MBDiagMan
Oct 27, 2004 11:12 AM
greebler
Aug 31, 2003 12:50 PM
vtec69
Nov 8, 2002 12:54 AM
