read this spark plug
Old Jan 14, 2014 | 06:36 PM
doood's Avatar
been there done that
Default read this spark plug
i was having issues with it knocking at low rpm/high load, basically cruising, so decided to do a street tune on it to try and sort that out. pulled this one out of cylinder 3 today. the rest looked similar, but with the tips intact. these are denso iridium ik22. replaced them with ik24's.
quick build break down:
k20/k24
svm 212 cams
wiseco 87.5mm 12.5:1
pump 91
Old Jan 14, 2014 | 06:45 PM
DDTECH's Avatar
Default Re: read this spark plug
Blurry pic.
Get new plugs, allow car to warm up, and go make a pull.
shut the car off before redline, few hundred rpms. Take a top pic, side pic and a pic of the strap.
For Cruising, you can run as lean as you want, as long as it doesn't break up or pose any type of accelerating issue. I tend to run most cars around 14.8-15.5 for cruising afr, make sure the timing is fairly advanced in light load areas, if its too low, it will buck or break up sometimes, same with it being too much.. typically 37-43 degrees seems to be the norm for partial throttling.. I can post a few maps if you'd like.
Old Jan 14, 2014 | 06:53 PM
doood's Avatar
it'd be gibberish to me
my tuner's taking it easy with the timing and cam angle. we've been making pretty good progress.
Old Jan 14, 2014 | 06:55 PM
DDTECH's Avatar
The cams are different. I just did a z3 head a few weeks back on a a2 block. I ran mostly 20 degrees VTC for cruising, 10-20 should be fine.
timing being easy, could be a issue, if you have little timing, a lot of fuel, its going to cause some issues. That plug looks f'n terrible, put a new set in and redo.
Old Jan 14, 2014 | 07:07 PM
doood's Avatar
it has a new set in now. we'll get back to doing some pulls tomorrow.
Old Jan 15, 2014 | 05:59 PM
doood's Avatar
new set of plugs after some easy driving and hard pulls
didn't realize #3 came out so blurry, but it looks like the other ones. it does idle smoother with these new plugs. did some more street tuning today, and knock has gone way down. still some there, but we're making progress.
zach1288
Jul 30, 2009 02:10 PM
See Are X
Jan 1, 2006 11:18 AM
eg4usdm
22
Sep 7, 2005 04:06 AM
chads
Jun 4, 2005 02:32 PM
alexsracing
Apr 24, 2005 04:01 PM
