98 honda accord ex 4cyl vtech
1998 Honda Accord 4cyl VTECH engine
Car Starts fine but once it hits 3000 rpm it stalls/chokes wont go past 3000rpm. It is not tranny as that was done 6months ago. I just did some work to car changed crankshaft seal. Timing was put back the same. I did some google researching and seen this does happen and people have change all kind of parts to no success, it starts and runs great except when you get to 3000 rpm will not go past it.
That being said, we have already changed alternator, MAF Sensor , TPS, Checked timing, changed distributor, distributor cap, new plugs, the only sensor we have not changed is the IAC. IAC is expensive, so we cleaned it and still doing the same thing. Can anyone tell me what this is? I really need some help here.. please.
Check for codes next. Verify the CEL light works when the key is turned to II(ON) if not then the bulb has burned out, and the easiest way to read the codes is via a OBDII code reader/scanner.
I've had this problem about 8 months ago. I got it checked out but the mechanic couldn't find out what it was. So I just drove it as is and after a few weeks it went back to driving regularly. Just try accelerating slow. Thats what I had done for the while.
Keelan E
Mar 26, 2017 12:41 AM
patelmd
Jun 17, 2012 12:26 PM
