frequent ignition coil failure
Old Jan 14, 2014 | 09:15 AM
marobi9181's Avatar
Default frequent ignition coil failure
My ignition coils (mfd by import direct) keep failing. They go bad after about a month of service. They get a crack visible in the plastic above the output. This time, im going to replace with a part by omnispark, but was wondering if another part on my car could be to blame. Hopefully on an unrelated note, the gauge cluster lights work intermittently. Thanks for any ideas!
Old Jan 15, 2014 | 05:37 PM
bheinen74's Avatar
Default Re: frequent ignition coil failure
have you just changed the coil, or have you tried to change out the ignitor as well?
I suggest you get a different ignitor.
Old Jan 18, 2014 | 08:53 AM
marobi9181's Avatar
After putting in a new coil, driving 20 miles, and breaking down- I swapped in the ignitor from my parts car. Wish me luck on my test drive.
byc_cb7
Aug 28, 2009 10:15 AM
95blackEG
Dec 24, 2008 06:12 PM
Doug684
18
Jan 11, 2004 03:28 PM
toooslow
Aug 20, 2003 09:12 PM
magic hat #9
Dec 31, 2002 06:53 PM
