Honda CR-V & Element 2WD & 4WD Element & CR-V
Just sharing some pics of my head gasket job 1999 CR-V
Old Jan 12, 2014 | 05:58 PM
blk1stgen's Avatar
Default Just sharing some pics of my head gasket job 1999 CR-V
So since adjusting my valves i noticed it was blowing smoke at idle i decided to replace the valve seals so i removed the head and sent it out to the machine shop to get cleaned and had them replace the valve stem seals , i spent around $300 total including labor ( i did the work ) , new head gasket, re used head bolts, new valve cover gasket, new intake manifold gasket, machine shop work and new coolant .
Overall i would say IF you are experienced with engines and these motors it is a 6/10 in difficulty , it was a straight forward job and the machine shop said the exhaust valves and seats were fine ( i asked because our B20 motors have the infamous exhaust valve seat problem ) .
So i put it all back together and have been driving even since .
it isn't difficult at all just a lot of tiny things that need to be removed and remembered .
Old Jan 14, 2014 | 08:03 PM
stangrcr1's Avatar
Default Re: Just sharing some pics of my head gasket job 1999 CR-V
Thanks for posting!
Old Jan 18, 2014 | 10:58 AM
laloquera916's Avatar
very nice right up, been there that seven years ago. I don't recall, but I was way under $300 bones. I torch down the head back and keepers on exhaust cylinder #3 came apart and heard the valve making that ping noise when it fell loose from the head and hit the top of the piston. I had to take it off and compressed the spring to a assemble the da valve back on, did it right on my dinning table. That was fun. The job is what it is, I was broke and had no choice to do myself, as for other, if you confident with ur wrench ability us should by all means dear yourself and push yourself. I did.
I need to send u a PM, let me know what you think on a related issues.
Thanks
93_delswol
27
Feb 18, 2017 07:52 AM
mediajunkie420
Oct 7, 2013 12:34 PM
prettylew
May 2, 2008 07:35 PM
98GSRDC2
Mar 5, 2007 10:13 AM
jeremy.
Feb 3, 2004 10:14 AM
