Eg hatch build Pic heavy
Old Jan 12, 2014 | 01:40 PM
Airhatch's Avatar
Default Eg hatch build Pic heavy
whats up HT sharing build and looking for some insight.
day i got the car in North Carolina
i have no idea why it was painted white in the front it had a d16z6 swap that smoked like a mother...
the whole left side and roof was totally sun faded
put a front lip and ebay coilover sleeves on it took the ugly hubcaps off
time to get rid of olde smokey
Old Jan 12, 2014 | 01:50 PM
Airhatch's Avatar
Default Re: Eg hatch build Pic heavy
painting the front end before clear
front bumper
assembly
finished front end, added spoon replica mirrors
Old Jan 12, 2014 | 01:54 PM
Airhatch's Avatar
so about that engine...
valve cover, painted black with A LOT of red pearl in clear turned purple
picked up some XXR wheels
out with the old
Old Jan 12, 2014 | 01:57 PM
Airhatch's Avatar
foglights?
engine in
now to pick up that head
installed
Old Jan 12, 2014 | 02:02 PM
Airhatch's Avatar
new engine in
wheels on with red lugs
black tow hooks
mild wire tuck ugly intake while i polish other
Old Jan 12, 2014 | 02:14 PM
Airhatch's Avatar
rolling shot friends driving since he cant use a camera to save his life haha
craigslist used air ride >.<
pics of it slammed
dragging it
pic from brown county truck meet there was one ef there so atleast wasnt too out of place.
Old Jan 12, 2014 | 02:21 PM
Airhatch's Avatar
super low rolling
candy red tail lights and ran on dyno at school made 113 whp
time to repaint this car
re assemble added twin loop exhaust
three wheeling it over MD can
river shot
Old Jan 12, 2014 | 02:39 PM
Airhatch's Avatar
time to re do all the air ride plumbing and sound system wiring
gathering all the b series stuff
lets get this thing put in
its in went with Skunk2 gen one intake tri Y header apexi noir exhaust edelbrock cams aem camgears crowler valvesprings and retainers race port wavetrack lsd and 6 puck clutch
Old Jan 12, 2014 | 02:47 PM
Airhatch's Avatar
planning a turbo build now and some new air struts to get rid of the awful cylinders im on.
Old Jan 12, 2014 | 03:04 PM
B_Swapped93's Avatar
b16 or a b18 ? you did get it properly tuned right once you put those cams etc in ?
Old Jan 12, 2014 | 03:07 PM
Airhatch's Avatar
its a b16A with a GSR head, and yeah i hade it tuned, it made 171whp and 132 ftlbs of torque
Old Jan 12, 2014 | 05:06 PM
Mike_ef's Avatar
keep it up
Old Jan 12, 2014 | 06:07 PM
Eddie's Avatar
Master Ninja
Great build love the look of it slammed. Keep up the good work
Old Jan 12, 2014 | 06:30 PM
gzes's Avatar
great build love hatches but have yet to get one. how much are you in on the air ride? gonna air ride my 5th gen lude
Old Jan 12, 2014 | 06:48 PM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
How does the air ride feel?
Old Jan 12, 2014 | 06:58 PM
Airhatch's Avatar
Well most of mine was used stuff but I'd say it roughly comes out to 1600 for cylinders that's no shocks, and 2100 for struts thats with shocks. I'm going to get struts because they ride even better. But the cylinders are actually not a bad ride. Much smoother than coilovers for sure just have to find right pressure, for me its 60-80psi unless I have a passenger than its 80-100 and 4 ppl 100-120 it all depends on the set up. Once I get back to my computer I'll do a list of the set up
Old Jan 12, 2014 | 07:27 PM
Airhatch's Avatar
ran 4 asco 3/8ths manifold valves all bolted together so you only need one supply in they run 130 each
air cylinders 3 inch < rear and 4 inch < front new they are 110 each
air tank I'm running a pancake air tank in the spare tire well with a false floor so my sub box dosn't break off the fittings. about 100 bucks new
fittings. they are effing expensive and you don't think about it.
I'm running as few as possible 7 3/8ths @ $11.00 11 1/4 inch $7.00 plugs are relatively cheap and u can get em at lowes i used all metal press to connect fittings they last long and you can remove an air line without having to re do a compression fitting, they also don't seem to leak
used compressor i used to have two but one locked up so im down to one
new ones run about 310 for a pair of viair 440C, fast fill times
best air air zenith they are about 300 for one, but are as good as two viaris
air line, relitively cheap i used all 3/8ths line for the suspension and 1/4 inch for gauges. could have used 1/8th but i didnt
water trap and drain, cheap but its NEEDED picked up mine at rural king for around 20 dollars
air brake antifreeze cold climate, it was -14 and my valves were frozen < no me gusta but the air brake antifreeze did the trick 7 bucks
switchbox u can pick or make your own, generally run about 40 dollars to 150 depending on your taste and style
gauges either digital or analog it all depends on the setup you get. roughly 30-100 per gauge
grand total i paid was roughly $900 but i used a ton of stuff off craigslist that is going to need replacing.
air cylinders are nice on a budget, but spend the extra money seriously and get struts you'll be happy you did.
Old Jan 12, 2014 | 07:55 PM
Derkeley's Avatar
Awesome job on the build! Definitely motivating for me get started on my EK hatch build.
Old Jan 13, 2014 | 03:18 AM
95Sedan's Avatar
I like that, complete & revamp write-up. Good job buddy
Old Jan 13, 2014 | 04:36 AM
gzes's Avatar
Lucky you live in a place where air ride is like candy. Down here I have yet to see air ride on craigslist at all. Not even hydrolics. Was the kit you bought honda specific?
Old Jan 13, 2014 | 03:37 PM
Airhatch's Avatar
No its actually super hard to find, I drove 300 miles to pick mine up when I was in school in Indiana, so it was dumb luck. I'm going to be replacing mine soon and will be getting rid of my cylinders they just need new o rings which are pretty cheap.
Old Jan 14, 2014 | 01:28 PM
estewar03's Avatar
Looking good so far. How long were you accumulating parts before you started the build/swap? Feels like I've been saving up parts for years, oh wait... **** it has been years FML.. I need to get **** rollin.
Old Jan 16, 2014 | 04:56 AM
Airhatch's Avatar
Lol it only took a week to get all the parts. Mainly machining stuff and port matching gasket surfaces took the most time, but I know how to build engines so that took a day and it took a week to get the right trans stuff and build it then an hour to drop it in and wire it up and get it started up. Tuning it I just drug it out to a tuner because I dont feel like screwing with it so that was a day. It didn't take long at all just know what u have to get in advance and know the market prices
Old Feb 4, 2014 | 05:53 AM
Airhatch's Avatar
well unfortunatly car is for sale new job is located too far away to drive my truck back and forth and id hate to put the 30K plus miles a year on this car.
Old Feb 4, 2014 | 11:11 AM
estewar03's Avatar
That's shitty. Personally I'd drive the **** out of it for that kind of commute.
