Distributor and wiring question
So I'm in the process of replacing my distributor and came across a wire coming from the battery that is spliced into the blue wire in the wiring to the distributor. All of the videos online that I have seen don't even make mention of this wire; anyone have any idea what this is? Do I need to splice it into the blue wire on the new distributor?
Shouldn't be necessary, i'd pull it, sounds a bit "rigged" up...It usually is run to the driver side as an rpm tach signal on cars pull the signal from the dizzy and not the ecu...
live4soccer7
12
Sep 26, 2013 06:26 PM
ozzyman
Sep 29, 2003 01:39 AM
ozzyman
