Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
03 accord v6 needs ECM, what other years will work??!!
Old Jan 10, 2014 | 03:44 PM
northcb7's Avatar
Default 03 accord v6 needs ECM, what other years will work??!!
I have an accord v6 coupe,2003, that my local dealer just diagnosed ECM failure, my car was shutting down every time it was not idling or getting throttle. Braking seemed to turn it back on as well. Problem is, oem ecms are on back order for a month, and this is my only car. Local scrapyard has an ECM from a 2005 accord v6 coupe, does anyone know if this will work?
Thank You
Old Jan 10, 2014 | 04:04 PM
goldsy's Avatar
Default Re: 03 accord v6 needs ECM, what other years will work??!!
Yes. 03-07 V6 Accord ECM's have the same part number. Any model, 2 dr 4 dr doesn't matter as long as it's a V6 ECM.
Old Jan 11, 2014 | 02:29 PM
northcb7's Avatar
Thank you.
Old Jan 16, 2014 | 07:20 PM
NightHawk92's Avatar
pretty much your Honda/Acura PCM/ECM is just a blank I guess you could say. Then when the dealership or your self programs it. With the HDS it becomes the vehicles personal thing. long its the same part number and is for 03 thru 07 Accords 4Dr sedans V6 models your good.
Old Jan 21, 2014 | 12:24 PM
CHONCH2's Avatar
When you say "ECM", do you mean "ECU"?
Never heard it referred to as an "ECM" before...
Old Jan 21, 2014 | 06:50 PM
goldsy's Avatar
Originally Posted by CHONCH2
When you say "ECM", do you mean "ECU"? Never heard it referred to as an "ECM" before...
ECU/ECM - same thing. Honda uses both terms. Unit/module, take your pick. Some other car companies use PCM (power train control module).
If you look up the part for the 2003 Accord it's actually called "module, engine control ECM"
Old Jan 25, 2014 | 12:55 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Nobody calls it an ECU anymore.....
Old Jan 25, 2014 | 12:59 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
PCM is used when the ECM/TCM is combined in one unit.
Old Jan 31, 2014 | 11:15 AM
CHONCH2's Avatar
Wasn't really sure nowdays. Only time I've ever messed with the computers is back when I was dicking around with the 92-95 Civic and 94-01 Integra stuff. Everyone refers to those as "ECU's". You say "ECM" regarding one of those, and people look at you like you're an alien.
72F250
Apr 16, 2019 04:40 AM
NemoDat
Acura TSX
Dec 11, 2012 05:08 PM
petey_97
Dec 22, 2011 08:09 PM
