Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Failure in TPMS on 2005 Pilot
Old Jan 10, 2014 | 01:08 PM
tpbeebejr's Avatar
Default Failure in TPMS on 2005 Pilot
My otherwise excellent mechanic sprayed a leak sealer into a tire with a small puncture that could not be fixed with a plug. This must have gooped up the tire pressure monitoring sensor (TPMS) in that wheel. Immediately after pulling out of his lot there was and is still a yellow TPMS light (a different light than the red TPMS light that shows which tire is low) that is always on.
Since then I had all 4 tires replaced and lost track of which tire it was done to. By letting air out of each tire and observing the red lights, I have been able to locate which wheel it likely is now. Three of the wheel sensors still seem to work and one does not (and now I know which one). I am going to assume that the non-functioning TPMS sensor in that wheel in the reason for the orange TPMS light being on continuously. Am I correct to assume this?
Does anyone have experience cleaning/fixing a single TPMS sensor like mine that has been exposed to leak sealant/goop? I haven't looked up the cost of a single in-wheel TPMS sensor yet, but for those of you with experience here, would you try to fix it or just buy a new one?
Thanks,
Tom
Old Jan 10, 2014 | 01:52 PM
lazlong's Avatar
Default Re: Failure in TPMS on 2005 Pilot
They're about $50. Tire shop should be able to put it on for about the price of a mount and balance. They should be able to get you new sensor too.
Murk13
Dec 16, 2019 07:44 AM
Frank S
Honda Accord (2013 - 2015)
Sep 25, 2018 10:50 AM
Grumpycloud
Mar 1, 2014 07:36 AM
passwordjdm
106
Dec 7, 2011 08:11 AM
EF_9
Jan 18, 2008 07:19 PM
