Early 88 crx si clutch spring Q
Old Jan 10, 2014 | 10:19 AM
thesmogman's Avatar
Default Early 88 crx si clutch spring Q
Hi All,
Looking for some knowledge here. I had my clutch pedal assembly break on me this last week.
Got it removed(What a pain in the back)welded up and installed, However I can not find where the clutch return spring connect's too. I pulled it off the pedal and left it hanging out and then found it on the floor.
Please note that this is an early 88 and I have not found thru searching alot where it is suppose to go.
Please help!!
thesmogman
Old Jan 10, 2014 | 03:06 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: Early 88 crx si clutch spring Q
Looks like there is a small hole in the bracket right
in front of the pivot point/nut that holds the brake pedal in place..
Old Jan 10, 2014 | 03:47 PM
thesmogman's Avatar
Thank's 88dxcrx, now I got to see if that is it. It has to be. That is the only spot I didn't look at.
thesmogman
Old Jan 10, 2014 | 03:51 PM
88DXCRX's Avatar
Sure man..
{Click that thumbnail for a larger version..}
You may have to use a small mirror
and flashlight to see exactly where the hole is..
xxpaulcpxx
Feb 2, 2011 11:44 AM
zerofighter009
Mar 24, 2010 08:55 PM
jdm206
12
Feb 21, 2006 03:22 PM
EF9 JAMS!!!
Oct 19, 2005 11:16 AM
sohctodohc
Nov 27, 2004 11:42 AM
