I NEED A NOID LIGHT FOR MY 95 CIVIC DX
Old Jan 10, 2014 | 09:20 AM
todenbach's Avatar
Default I NEED A NOID LIGHT FOR MY 95 CIVIC DX
I see in the posts that several folks have used a noid light. Looking in my town and online I can't find a kit that mentions that it will work with Honda's. If they won't directly plug into the harness is it ok to use jumper wires from the light to my harness? I am an older guy and it is difficult for me to get to the ecu wiring and this seems like a much simpler way to see if the ecu is grounding the injector coil. I would really appreciate your advice on this.
Old Jan 10, 2014 | 09:50 AM
Mr. Dabolina's Avatar
I got a noid light kit at Advance Auto Parts last week for my 2000 Civic. Its mostly a GM/Ford kit but I was able to use the noid light labeled for Bosch injectors.
I know my injectors use different clips than yours but the pins look like they're the same size and the same distance apart.
Old Jan 10, 2014 | 11:36 AM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
Default Re: I NEED A NOID LIGHT FOR MY 95 CIVIC DX
You can try probing 2 wires from a single filament bulb into the injector clip.
Or you can use a volt meter as well
Old Jan 10, 2014 | 01:30 PM
You must have a nicer volt meter than me because mine wouldn't switch over fast enough to show a pulse. Even on a good cylinder.
Old Jan 10, 2014 | 03:08 PM
Former User's Avatar
Just use a test light.
Old Jan 11, 2014 | 12:17 AM
Shit Posts: 15
10 Year Member
I guess I do /:
Old Jan 17, 2014 | 10:56 AM
todenbach's Avatar
Thanks to everyone that offered help. The light bulb trick worked well. It worked so well that the car started up when doing the test. I had already replaced the main relay so I am leaning towards an ecu that works intermittently. If anyone has other ideas I am open to suggestions.
Old Jan 17, 2014 | 03:09 PM
I can send you a link on how to test the transistors in the ECU if you're interested. I was going through the same thing a few weeks ago.
Old Jan 17, 2014 | 04:40 PM
Shit Posts: 15
10 Year Member
Youre welcome.
davesrex
Jun 12, 2007 08:43 PM
JLEK
Audio / Security / Video
May 13, 2007 01:03 PM
demozast
May 31, 2006 02:42 PM
AndyD
Mar 17, 2005 06:06 AM
