Transmission & Drivetrain Gearboxes, Differentials, Clutches
B16 Clutch Bleeder Valve Thread Size!!!???
Old Jan 10, 2014 | 04:44 AM
Supernewb's Avatar
Default B16 Clutch Bleeder Valve Thread Size!!!???
I need to know the thread size of the clutch bleeder valve on the slave cylinder. If someone could provide the dimensions of the bleeder vave screw, length and thread size that would be great.
I need to find a bolt size to plug it so that I can fit my new header on.
Old Jan 12, 2014 | 06:10 AM
94EG8's Avatar
Seagull Management
Default Re: B16 Clutch Bleeder Valve Thread Size!!!???
I believe it's 8mm x 1.25
Old Jan 12, 2014 | 11:34 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
How will you bleed it then? Your best bet would be to just shave off the nipple if you can get away with it. Sounds like a poorly designed header if you can't keep a bleeder screw.
Old Jan 12, 2014 | 12:55 PM
94EG8's Avatar
Seagull Management
You can bleed at the line, or even at the bolt. It is kind of a poor header design though.
lsvtechatch92
Jan 6, 2008 04:48 AM
lsvtechatch92
Nov 21, 2007 08:33 PM
civic91
Nov 15, 2005 10:34 AM
H22ek4
Jul 8, 2003 03:45 PM
