Fog lights stays on
Hello, my battery died and didn't notice until after jump starting it for a couple of days. I thought it was due to it being cold here in Jersey.My fog lights stay on even after the car is off and thats what caused my battery to die. I unpluged the fog light switch and it is still on. It just suddenly happened . I did not work on the car or anything. I'm going to unplug the bulbs for now. Can someone help. THANKS.
Maybe you could check your reply switch and fuse that came with the fog fight kit to see if either is has a problem.. Hopefully you have that..
The relay is frozen or worn out. You can test that by unplugging the relay and plugging it back in. If it's working right you should hear and feel it clicking. If it does click you have a short to power or ground somewhere.
jArceo
Feb 14, 2006 11:25 AM
