Car sluggish before 4k rpm
I have a b16 with a p28 ecu.
At times my my car will lag before reaching 4k rpm.
once i hit 4k rpm the car picks up quick (like a mini vtec) then the vtec crossover at 5k.
When this happens i have to cut the motor and cut it back on then its back to normal. It's annoying and I don't want this to lead to bigger problems.
plz help
93 hatch, b16, short ram intake, and p28.
other than that its stock.
plz help
I don't think that ECU goes with that motor, then again, you've not given enough details to properly identify a major issue, so :/
Year/Trim
Swapped?
Miles?
ODB?
Year/Trim
Swapped?
Miles?
ODB?
Lemme guess. You just bought the car and know nothing about it?
p28... Great and all, but is it socketed with a chip that has a basemap for that motor?
If the motor is running off the correct ecu, then look into the standard tune-up preventative maint parts.
im having similar problem but when i hit vtec range i lose power and back fires. oil is good, solenoid tested and works what else can i check?
running stock 92eg hatch with d15 sohc vtec
madcrx69
Engine Management and Tuning
Jul 21, 2009 08:42 AM
black-ek9
12
Apr 6, 2004 01:29 PM
