FS: ClutchMasters Flywheel
Old Jan 9, 2014 | 06:34 PM
NorCal EM1's Avatar
Default FS: ClutchMasters Flywheel
For Sale:
Clutch Masters Aluminum Flywheel
Used
B Series 9Lbs
You can purchase the replaceable insert to make this flywheel essentially new.
$100
Product Description
Clutch Masters 2-Piece Billet Aluminum Flywheels are made from the highest quality 6061-T6 or better grade aluminum. This material is chosen for its properties that are much more suitable for the environment than the one-piece chromoly units, with regards to heat dissipation and serviceability. The replaceable friction surface used is incredibly tough high carbon steel. This allows mating with any type of clutch friction material without worry. The starter ring gears are made of high carbon heat-treated steel for long lasting durability. The unit is buttoned together with military grade fasteners to make the premier flywheel in the industry.
Features
  • Reduced mass equals increased acceleration.
  • A lightweight flywheel works particularly well with turbo-charged engines because it reduces typical turbo lag.
  • Increased supercharger efficiency due to less parasitic drag on the crank.
  • Improved mid-range torque in a normally aspirated engine due to not having to overcome the heavy weight of a stock flywheel.
  • CM uses only 6061-T6 aircraft grade or better billet aluminum in the manufacturer of its flywheels.
  • CM uses High Carbon steel for the friction surface. (Replaceable)
  • CM uses an OEM steel ring gear secured by bolts.
  • CM offers a limited lifetime warranty.
  • CM Billet Aluminum Flywheels meet SFI Spec 1.1 or 1.2
Old Jan 13, 2014 | 04:35 PM
NorCal EM1's Avatar
Default Re: FS: ClutchMasters Flywheel
bump
Old Jan 23, 2014 | 03:35 PM
NorCal EM1's Avatar
obo
Old Jan 24, 2014 | 05:43 AM
Slamaccord's Avatar
chea!!
Old Feb 16, 2014 | 12:25 AM
NorCal EM1's Avatar
wooo!
Old Mar 11, 2014 | 07:20 PM
NorCal EM1's Avatar
$40 dollar price drop! lets get this moving!
NorCal EM1
Mar 18, 2014 11:03 AM
regamaster
Oct 26, 2007 04:40 PM
Rocks
Aug 23, 2004 12:27 PM
dynamo
May 13, 2004 07:46 AM
-=TWITCH=-
May 15, 2002 10:21 PM
