carbon fiber hood delaminating repair
Old Jan 9, 2014 | 04:27 PM
raverx3m's Avatar
Default carbon fiber hood delaminating repair
theres about 1000 of clear coat repair articles but i just bought a hood thats delaminating on the sides and the top is separating from the bottom frame. i got it for 30 bucks
anyone has a an article about the hood repair
from what i gathered so far.
i clean the contact areas (spray with carb cleaner?)
use epoxy to glue the layers back together.
lightly sand the top and reclear.
questions i couldnt find
there are hood pin holes. can i fill them up with epoxy and then lay a small piece of carbon fiber sheet on top to cover the holes so at least it matches the weave somewhat close enough.
i will post some pictures later
Old Jan 9, 2014 | 09:07 PM
raverx3m's Avatar
Default Re: carbon fiber hood delaminating repair
initially i was planning to just color match it to the car or vinyl wrap but if i can get the holes somewhat clean i might just reclear it
Old Jan 10, 2014 | 04:20 PM
raverx3m's Avatar
just want to know what are the better materials to use for this job.
maybe specific brands and types would be great
Old Jan 10, 2014 | 04:28 PM
Hidenplanvew's Avatar
Lord fuser makes an adheasive that will fix the seperation but its about 40 bucks. I think you use the one for fiberglass, it will make a much strong bond then epoxy.
Old Jan 10, 2014 | 05:45 PM
raverx3m's Avatar
should i use epoxy or urethane adhesive?
Old Jan 12, 2014 | 04:02 PM
raverx3m's Avatar
anything i can pick up locally from napa or wesco?
Old Jan 12, 2014 | 07:42 PM
Napa might be able to get it but I am unsure. Lord fuser makes a ton of adheasives you will have to go to their website and look through what they have to offer. I am sure that that 3M has something that would match too.
Old Jan 14, 2014 | 08:08 AM
spray2020's Avatar
You can just use a fiberglass filler and then clamp the hood shut made by 3m.
Those areas where the clear is gone, it looks as though the carbon has been sanded through the weave? Did you sand it or was that the sun's doing? If you can manage to sand all of the other clear areas and re-clear it should look good- but those areas where the weave is damaged you will notice.
Old Jan 16, 2014 | 09:40 PM
redboost10's Avatar
You can always just separate the two layers and discard that bottom and reinforce the hood with some honeycomb cross bracing. I separated mine on purpose beings weight is a concern on my car for the particular class I run in.
As for the finish, just scuff it up and reclear it
TwotoneC1Da9
Paint and Body
Jul 29, 2010 10:57 AM
grape1161
Jun 1, 2009 07:29 PM
feriotypeR
Welding / Fabrication
Dec 7, 2008 03:48 PM
Eklsv-t
Paint and Body
Jul 28, 2008 02:29 AM
SwampThing
Sep 6, 2005 02:51 PM
