Suspension & Brakes Theory, alignment, spring rates....
94 Integra upper control arm question
Old Jan 9, 2014 | 02:38 PM
92ludeSIB's Avatar
Default 94 Integra upper control arm question
Bought new upper control arms but they werent marked left or right anywhere i looked...if i just put them on will it be ok if they are backwards?
Old Jan 9, 2014 | 02:44 PM
90_EX_Civic's Avatar
Default Re: 94 Integra upper control arm question
will not be okay if you put them on backwards. you have to make sure they are on the correct side, or your caster will be off.
do you still have the old ones on the car? if you do, just match them up
Old Jan 9, 2014 | 02:53 PM
92ludeSIB's Avatar
the old ones werent marked either and looks (to me) identical when placed side by side..... the boxes the new ones came in have no part numbers or else i would look them up...
Old Jan 10, 2014 | 01:28 PM
well, if they match up... you might be lucky and it might not matter. but even acura has it listed as a right and left....
Old Jan 10, 2014 | 02:44 PM
TunerN00b's Avatar
It does matter which side they are installed on. They aren't symmetric.
Swapping the UCAs left to right will add 1.5° of caster, taking the car well out of the factory alignment specifications and reducing the available bump travel (the UCA hits earlier than it should).
I did that on purpose, and now have dented shock towers...
Slodc01
Suspension & Brakes
Jul 29, 2016 01:16 AM
Hunters teg12
Suspension & Brakes
Aug 3, 2013 12:39 PM
rogue420
Aug 6, 2010 07:12 AM
CivicSiDriver02
Oct 20, 2005 07:28 PM
