00 Civic Trunk Light on Dash
Hey guys, I have a 2000 Civic Hatchback, I recently changed my cluster and adjusted my trunk latch the same day.. Now the trunk light is on the dashboard as Open, even when it's closed properly.
I searched the forum and google. I got a little information on what might be going on, some people say the trigger for the dash light is built in the latch on the trunk it self, is that correct?
If I pull the latch off the trunk it self and pull the hook off the body, will I be able to verify if that's where the issue is? if not, what else can I check?
Thanks guys
Thanks guys
yes unplug the sensor in the trunk. aparenty its sensing its open...
unplug it or fix it....
or take out your cluster and take out the trunk lid open light bulb
Thanks for your reply, btw I like your sigs lol
take the connector on the latch and slowly and lightly push it to one side or another and check for operation. theres just a metal tab that the latch grounds when they touch. i think youll need to pull the top a little to the drivers side.
Edit- just saw you have a hatch. i bet the latch is difrent than the one i explained. Mine had a removable cover over it on my sedan.
yeah first unplug the sensor or the latch, is the light off? then try 'closing' the latch with a screwdriver and see if you can get the light to turn off by pressing harder, or pushing more on one side etc... if nothing changes it's probably a bad switch/sensor or just needs adjusting
DragonBoy
21
Oct 25, 2017 04:26 PM
Andrewzabomb
Feb 21, 2012 12:32 PM
