00 civic wont start - no power to distributor
Old Jan 8, 2014 | 11:00 AM
Jason Combs's Avatar
Default 00 civic wont start - no power to distributor
There is no spark out of spark plugs.....and no power to my distributor
Old Jan 8, 2014 | 11:05 AM
Sccacivic1997's Avatar
Default Re: 2000 honda civic wont start
Replace the distributor
Old Jan 8, 2014 | 11:06 AM
Former User's Avatar
Check dash fuse 9
Old Jan 8, 2014 | 11:43 AM
I checked the fuse its good.... Would replacing the distributor fix it not getting power...the connector isnt getting power this mechanic tested the red wire he said it was the hot wire
Can i post pics of it on here?
Old Jan 8, 2014 | 11:49 AM
He tested the wrong wire. The Blk/Yel wire should have battery voltage.
Old Jan 8, 2014 | 11:52 AM
The one under the yellow and green one? I have had to changed the coil before is this because i have 4 6x9s hooked up without an amp?
Old Jan 8, 2014 | 12:06 PM
checked it with the ignition on and no light came on the tester
Old Jan 8, 2014 | 12:18 PM
Voltage test fuse 9 - click the Fuses link in my signature.
Old Jan 8, 2014 | 12:52 PM
I did already the fuse isnt blown , when i keep trying to staqrt it i lose power quick and my car dies after the 4 time
Old Jan 8, 2014 | 12:54 PM
Did you voltage test fuse 9 exactly as described in my Fuses link? If so, what were the results?
Old Jan 8, 2014 | 01:06 PM
all i have is this tester that has a clip idk where to put the clip....he clipped it onto the battery to test the wires
Old Jan 8, 2014 | 01:08 PM
Did you read my thread? Instructions can be found there.
Old Jan 8, 2014 | 01:43 PM
I just checked it its good it lit up.....i checked the spring on my coil pack and it didnt light up
and the battery is almost completely dead after doing that
Old Jan 8, 2014 | 01:44 PM
You tested both fuse tabs?
Old Jan 8, 2014 | 01:45 PM
After doing what?
Old Jan 8, 2014 | 01:59 PM
yes i tested all my fuses to just to make sure. After testing the fuse i tried to start it again and it sounded like it was dieing when i tried to turn it over
Old Jan 8, 2014 | 02:00 PM
Thank you for helping all the mechanics here dont work on civics
Old Jan 8, 2014 | 05:37 PM
could it be my main relay
Old Jan 8, 2014 | 05:53 PM
Fatchance187's Avatar
You should be able to hear your main relay give an audible click right before you hear the fuel pump prime when you turn the key. You don't have to have the starter engage for this to happen, just turn to accessory. The main relay is by the glove box if memory serves. If it doesn't give an audible click that is a bad sign.
Old Jan 8, 2014 | 08:10 PM
I hear a click when i turn the key then like 2 seconds later another click. My fuse is good , Im not getting any power to my connector that connectx my distributor and coil.
Old Jan 9, 2014 | 10:06 AM
If both tabs of fuse 9 have battery voltage and the Blk/Yel wire in the distributor lacks voltage, then the Blk/Yel wire or Red wire is broken between those two points or the wire terminals lack contact in connectors (C120, C101, C419) between those two points.
Old Jan 9, 2014 | 12:06 PM
If both tabs of fuse 9 have battery voltage and the Blk/Yel wire in the distributor lacks voltage, then the Blk/Yel wire or Red wire is broken between those two points or the wire terminals lack contact in connectors (C120, C10, C419) between those two points.
What do i need to check for? i dont understand any of that its my first time with this. Could my main relay be bad?
Old Jan 9, 2014 | 12:11 PM
No, a bad main relay would not prevent voltage from reaching the distributor.
I rarely say this, but you may need to hire a mechanic as I don't think you can follow simple instructions. For example, based on your responses, I'm still unsure whether you tested fuse 9 as I suggested.
Old Jan 9, 2014 | 12:18 PM
i did i hooked the clip up to the metal under the dash like it said and then tested both points on the fuse and it lit up on both......my mechanic keeps telling me its the main relay...no one else here works on civics. I can provide a picture showing i tested the fuse. The first time i didnt read your link then i did and understood what to do.
