driver side door switch
Old Jan 8, 2014 | 10:36 AM
k_than's Avatar
Default driver side door switch
hello i wondering if anyone had this issue and were able to resolve it, so my issue is i have 97 honda civic 4door all 3 of my doors trigger the dome light passenger and 2 rear however my driver side does not,the driver side does give the chime with key in ignition as well as buzzer with headlight on but it does not trigger dome light to come on.
any help will be appreciated thannks in advanced
Old Jan 8, 2014 | 11:12 AM
Former User's Avatar
Default Re: driver side door switch
DX, EX, HX?
Could be a problem with the integrated control unit or a broken Lt Grn/Red wire.
Old Jan 8, 2014 | 12:24 PM
k_than's Avatar
Dx, if there is a problem with the icu will the door switch still send a ground signal?i basically installed an alarm on the car all doors trigger the alarm except the driver side, so i was thinking if i cannot get the dome light to work if i can just tap driver side door switch with diode to alarm door trigger which is also connected to light green/red wire behind the icu and wondering if that will set off the alarm for driver side.
thank you for the fast reply
Old Jan 8, 2014 | 12:27 PM
Sounds like your alarm install is causing the problem.
The alarm install should have been mentioned in the first post.
Old Jan 8, 2014 | 12:34 PM
k_than's Avatar
my apologies about not mentioning the alarm install, before the alarm install the driver side door still did not trigger dome light to come on when door is open all other doors does trigger dome light and alarm. im still not sure what can be done to either the alarm to work properly as well as dome light for driver side door.
door chime does work which leads me to believe door switch is still good.
any help is greatly appreciated
Old Jan 8, 2014 | 12:37 PM
Only the driver door switch signal for the dome light passes through the ICU. The door switch signal of other doors for the dome light bypasses the ICU.
Old Jan 8, 2014 | 12:38 PM
k_than's Avatar
bad ICU?
Old Jan 8, 2014 | 12:41 PM
Originally Posted by k_than
bad ICU?
Old Jan 8, 2014 | 12:55 PM
k_than's Avatar
thank you for the image, i did tap my alarms door trigger wire to the lt grn/red wire in the plug that plugs into the icu as shown in the image. and the image does show the lt grn/red ties with the grn wire, but my alarm still does not trigger with driver side door open as well as dome light
Old Jan 8, 2014 | 01:00 PM
Open only the driver door and then test for continuity to body ground at the Lt Grn/Red wire in ceiling light and also at pin B6 of the ICU. Is there continuity to body ground at either location?
Old Jan 8, 2014 | 01:03 PM
k_than's Avatar
i will check that this weekend and report back.
thank you for the help and fast reply
Old Jan 8, 2014 | 01:58 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
If the driver's door switch is working properly, which sounds like it may since "driver side does give the chime with key in ignition as well as buzzer with headlight on"; one way would be to splice a wire from the driver's door switch's Green wire to the Lt Grn/Red wire for the ceiling light at connector C401. Connector C401 is a 14P gray connector located behind the driver's kick panel. The green wire is at pin 10 and the Lt/Grn wire is at pin 11 at this connector. These wires are to provide the ground for the ceiling light when the door(s) are opened.
Note: Lt Grn/Red is a wire with light green insulation and a red-stripe.
Old Jan 8, 2014 | 03:07 PM
k_than's Avatar
by doing that adding a jumper between the drivers door switch grn and the lght grn/red wire that will trigger the dome light to come on with driver door open?
Old Jan 8, 2014 | 03:27 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
If the driver's door switch is good, yes.
Old Jan 8, 2014 | 03:33 PM
k_than's Avatar
it should be good door chime and buzzer working with driver door open.
i will try that this weekend and report back with results
thank you for your help
Old Jan 8, 2014 | 04:29 PM
Bypassing the ICU will activate the chime and buzzer by opening any door.
Old Jan 8, 2014 | 04:35 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Old Jan 13, 2014 | 08:02 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
You could also add a diode to the jumper wire so that the chime and buzzer still only come on when opening the driver's door; but, not from opening other doors.
Old Jan 13, 2014 | 09:48 PM
k_than's Avatar
I could not figure out why drive side door switch wire would not see ground.so i just ran a new wire to the switch and added a diode to the alarm.alarm now triggers with all doors.dome light not coming on wasnt really bothering me.
Thanks for all the input and help they are greatly appreciated
H9Omega
Sep 9, 2007 02:38 PM
TehMoonRulz
Jun 29, 2005 09:31 AM
AznJammyJam
Audio / Security / Video
Oct 7, 2004 01:51 AM
suspendedHatch
13
Apr 28, 2004 07:50 PM
kicker1_solo
Aug 21, 2003 11:29 AM
