Need Help On My Build???
Old Jan 8, 2014 | 08:27 AM
VTLX 03R's Avatar
Icon2 Need Help On My Build???
Okay, I have a B18c5 head and is rebuilt to 0miles, and was thinking about going with my stock CTR cams or should I upgrade to an after market for better performance due to my CTR pistons?? My block is also a B18c5 and I have CTR pistons in it and I'm running with a B18Ls Crank with P73 rods on it, everything is already together for the block but was wondering what Head gasket should I get to make it work rite?? And for the head studs should I get ARP Gsr or Type R?? Need Help??Anything??? Thanks
Old Jan 8, 2014 | 09:32 AM
TheShodan's Avatar
Moderator
Default Re: Need Help On My Build???
It all depends upon what you want to do with this setup. Its not all that "cookie cutter" when it comes to these decisions. You can either keep the B18C5, convert it to a "GLSR" using the LS crank , or run LS/VTEC. It's all here, its just a matter of finding the information, which is well posted here.
A discussion on the "GLSR" (B18C block using LS Crankshaft and LS Rod Length)
https://honda-tech.com/forums/showthread.php?p=49242491
How to build a proper LS/VTEC so that you can read about what headgaskets and studs to use (*Hint* OEM is best)
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/
If you plan to stay stock Bottom end, keep the camshaft choice OEM, or simply a mild upgrade.. There are plenty of choices to go with, so check out Google keyword Honda-Tech: to find the information regarding the cam choices as well as opinions of each type..
Don't forget the FAQs at the grayed areas of this particular forum:
Some "Heads UP" information to know right off the bat
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/%7C%7C%7C%7C%7C-new-members-please-read-%7C%7C%7C%7C%7C-2917915/
Standard FAQs
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/all-motor-forum-%5Bfaq%5D-2628364/
When in doubt... read it again...Good luck to you, and welcome..
Old Jan 8, 2014 | 09:50 AM
VTLX 03R's Avatar
Thanks for the info but what I really want to know is which Head Gasket, Head Stud and Cams shafts -jus because everyone keeps on saying u need some stronger cams for ure CTR pistons, already have the head/block done already jus need these parts left but undecided/unsure???
Old Jan 8, 2014 | 10:06 AM
TheShodan's Avatar
Moderator
Those links will answer those questions, and I even provided a *hint*
Old Jan 8, 2014 | 12:16 PM
VTLX 03R's Avatar
Wow yeap Rite On man!! So guess I'm goin with Pro1s as for the Camshafts and Stock OeM B18c5 HeadGasket sounds Good enough for my Ls Crank wit CTR pistons & ARP LsB20 V-tec Headstuds-CheapeR-!! Thanks Alot TheShodan
Old Jan 8, 2014 | 01:13 PM
HYREV2NR's Avatar
TheShodan is the "shizzle" here. He won't steer you wrong. I'll probably bug him to death when I start my build lol.
SanadaSand207
May 23, 2018 02:59 PM
ekVic214
16
Sep 5, 2011 01:34 PM
trucdoken
Mar 11, 2005 08:46 PM
arw321
May 9, 2003 03:12 AM
