93 Civic/ZC with EX head swap - idles at 2500rpm and strong gas smell
I just bought this 93 coupe with zc motor with ex head and its idles at 2500rpm.. can i get some help? its been awhile since i've played with a honda motor.
Also, the gas smell from my car is heavier then normal.. what can my problems be?
Ummm...gas leaking
Is it actually a gasoline smell, or can it be an exhaust leak smell?
You really are giving much info for anyone to go off of. More details would help.
After check for fuel leaks as the guys recommend, if you not found any I have a few in the shop with purge valve broken hoses (vent line to charcoal canister)
It's coming from my exhausts but it's strong not like a normal car.. Can it be cause I don't have a CATBACK?? The person who I got it from has some kind of after market OEM exhaust on it . does that make sence? I bought the car for 300 for a winter beater
1993 Honda civic ex red the motor isn't not stock it has a ZC block with an EX head I didn't do the swap bought like this.. It doesn't smoke so I'm not sure if it's running rich. Haven't check the codes yet kind I work on the pipelines so I'm away from home.
scott757
Sep 9, 2013 04:00 PM
cb7tuned
Oct 10, 2009 06:41 PM
l
Mar 15, 2002 10:55 AM
