Oil sludge on inner plate under valve cover : normal ?
Old Jan 7, 2014 | 07:30 PM
curvenut's Avatar
Default Oil sludge on inner plate under valve cover : normal ?
Hi,
I just change my PCV valve on my Accord 1996 EX (canadian car).
When looking into the hole , I can see some oil residu about 1 or 2 mm thick.
The residu is on the plate that is under the valve cover. I took a picture of the residue :
Is that normal ??? Will that sludge will clog my PCV valve ?
I would like to add that I just replaced the spark plug seals as well as the valve cover gasket. And the the rocker arm is clean, no sludge , no residu
It looks similar to this one (not my engine):
and the underside of my valve cover was similar to this (not my engine) with that brown coating that I cleaned with brake cleaner.
Old Jan 7, 2014 | 08:34 PM
HonBeer's Avatar
Default Re: Oil sludge on inner plate under valve cover : normal ?
Looks normal to me. If the PCV valve is clicking it is working. You could remove the valve and clean it with carb cleaner.
Old Jan 8, 2014 | 06:24 AM
curvenut's Avatar
Well, I already clean the PCV valve with brake cleaner but after couple days, it was clogged again, it doesn't click when I was shaking it.
That 's why I changed for a new one.
Old Jan 8, 2014 | 09:39 AM
HonBeer's Avatar
Change the oil then.
toyonda
Oct 20, 2009 08:20 AM
garykf16
Apr 13, 2009 04:09 PM
b20beast83
Feb 4, 2009 01:23 PM
itsdatdncguysal
Sep 18, 2005 10:29 PM
Spec R
Jan 15, 2005 06:28 AM
