Understanding Scan Data
Old Jan 7, 2014 | 05:51 AM
afnan's Avatar
Icon2 Understanding Scan Data
I have honda Accord 98 with F18 B engine. Today i went to scan it and following are all sensor readings. I wonder how to check them as there is no normal or abnormal range.
Old Jan 7, 2014 | 06:38 AM
GhostAccord's Avatar
Default Re: Understanding Scan Data
What sensor did you want to know about specifically?
A shop manual usually has the information that you are looking for. I'm not all that familiar with the F18 but I would assume that most of the sensors are calibrated the same as the North American F22/F23.
I see that your TPS is reading a bit weird. The TPS should read approx. 0.5v @ closed throttle & approx. 4.5v @ wide open throttle.
Old Jan 7, 2014 | 07:07 AM
afnan's Avatar
I was worried about O2, Short Term Fuel Trims and Spark Advance
Old Jan 7, 2014 | 07:37 AM
Yeah I'm not sure what your scanner is using for units on ST & LTFT? Mine uses %. It can flip between -25% & 25% before you get a CEL for lean or rich AF mixture. Depending on what % you are seeing it can tell you quite a bit about how your engine is performing. I have no idea what your units are telling you..unless that is 1.5% & 1% witch is really good.
Your timing seems a little bit on the retard side compared to the base 13°-17° that I usually see for the 2.2L. Have you made any changes to your ignition timing?
Old Jan 7, 2014 | 05:03 PM
afnan's Avatar
Nops no changes ti timing. Hiw can I verify the timings? This is Odb2b car so timmings are done by ecu.however I plan to check if timing is of by a tooth or so
Old Jan 8, 2014 | 03:25 AM
MAD_MIKE's Avatar
MM Gruppe B
Could you post a picture of your cars diagnostic connector. Or look over this link for what data connector is coming off the car http://alflash.com.ua/honda.htm
I thought you were in the EU, and EU did not get OBDII til '01.
EOBD DTCs http://alflash.com.ua/OBDII/EOBDcodes.pdf
There are the 3pin(OBD) and 5 pin(OBD) to 16pin OBDII adapters that come with some scanners which will allow some readout but may not be all or may be slower than anticipated.
Old Jan 8, 2014 | 07:44 AM
afnan's Avatar
Well my car engine was a JDM engine. Having said that it is ODB2B ECU i verified its wiring many many times. I Installed 16 pin DLC my self. It has K-Line Interface
xcxeon
Jan 24, 2018 04:05 PM
bdpackard
Aug 9, 2017 04:21 PM
truublue02
Dec 3, 2009 03:47 PM
mayflower
Nov 18, 2005 05:33 PM
