HP GSR axles can take...
well they sure as hell can't take 600 whp!!!
keep in mind that a larger wheel with a smaller sidewall increases the shock factor on your axles.......and http://www.driveshaftshop.com is a good place to start looking at aftermarket reinforced axles.
you can break stock axles with 250hp if you have a stiff clutch and do stupid hard launches.
with 600hp i am guessing you're running a drag only car so you'll need aftermarket axles to handle those launches.
