91 crx driver side lock wont work
The key won't turn the outside of the driver door . It locks from the inside and the passenger door locks and unlocks fine . I took the panel off and im not exactly sure what the problem could be , the lock on the inside of the door seems kinda messed up . any suggestions ? thank you
Is your key worn down ? I had a similar problem, and i bought a new OEM Honda key blank, got it cut at the dealer, and I havent had a problem since.
The problem was after 24 years, bad duplicates of bad duplicates were made, and the key was worn down to nearly nothing. Hows your key look ? If that doesnt fix it, perhaps previous owner changed out the lock.
gezulu
Honda Civic (2001 - 2005)
Sep 13, 2008 04:02 PM
TylerC161
Apr 11, 2008 03:16 PM
zach1288
Feb 6, 2007 08:34 AM
