z6 block with b7 head????
Old Jan 2, 2014 | 08:10 PM
matt2775's Avatar
Default z6 block with b7 head????
I just installed a b7 head on a z6 block. It all lined up everything seems fine. Will i be okay or was i supposed to open oil ports or somthing of the sort? Please answer back thanks
Old Jan 2, 2014 | 08:22 PM
B_Swapped93's Avatar
Default Re: z6 block with b7 head????
Do you have the correct ECU and have the VTEC sol/oil pressure switch hooked up ? if so you're good to go.
Old Jan 2, 2014 | 08:25 PM
matt2775's Avatar
I have the stock vtech ecu. And were is the pressure switch located?
24TEN's Avatar
PHANTOM MENACE
He did it backwards. Check the FAQ, I did a write up on exactly this specific combo and the oil control issue is covered in it.
Old Jan 2, 2014 | 08:27 PM
matt2775's Avatar
So it should be fine?
Old Jan 2, 2014 | 08:29 PM
I have a feeling according to 24ten you put a non VTEC** head on a VTEC block....lol
Old Jan 2, 2014 | 08:30 PM
matt2775's Avatar
Yes i did. Will it be okay ??
Old Jan 2, 2014 | 08:33 PM
You literally did it backwards you NEED a VTEC head you have a NON-VTEC head....so you will not have vtec at this point no matter what with that current head. Go find a z6 or y8 head, the whole "mini me swap" is putting a vtec head on a non-vtec engine block.
Old Jan 2, 2014 | 08:35 PM
matt2775's Avatar
Yes i know im not worried about the vtech i just want a running car it should work just fine or no?
Old Jan 2, 2014 | 08:41 PM
yes you'll be fine if you just want it running.
Old Jan 2, 2014 | 08:50 PM
matt2775's Avatar
Coo appreiate it thanks
Old Jan 2, 2014 | 09:08 PM
24TEN's Avatar
PHANTOM MENACE
Sorry, it was actually in the FAQ for the older civics.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/how-d16z6-block-d16a6-head-2754616/
neroren
Mar 16, 2009 04:26 PM
ZCcivicBOI
Nov 23, 2007 06:41 PM
bobalee
Oct 16, 2007 11:53 PM
hondakid88
36
Aug 24, 2007 12:05 AM
