Lowering spring and shocks or coil-overs?????
Old Oct 28, 2002 | 11:01 AM
accordblk's Avatar
Default Lowering spring and shocks or coil-overs?????
Hi, I have '02 accord coupe and i'm planing low my car, and get 17inch.
i have no idea what i'm gonna do or how much i'm gonna spend...
and if i get coil-over, do i need anything extra like other shocks or anything??
i heard i need sport shock for lowering spring... i need help~~~~!! PLEASE~~
HELP!~!~!~!!!!!!
AND... ANY RECOMMENDATIONS????
Old Oct 28, 2002 | 11:20 AM
Stew Pidasso's Avatar
Default Re: Lowering spring and shocks or coil-overs????? (02accord2dr)
Click on the search link in the upper right hand corner and you will find a wealth of information. Use keywords such as Koni , Tein, H&R, shocks, suspension and search these all in the Accord forum. Then when you have an idea of what your looking for, post a question.
fcardoso's Avatar
Well technically speaking you should use adjustable shock with coil-over!!
And you will need a camber and caster adjusting kit to compensate for the amount that you lower or use the suspension techniques adjustable control arm kit!!
As for which is better, the coil-overs are a stiffer ride compared to springs that are made for a certain amount of lowering!!
Old Oct 28, 2002 | 07:28 PM
iam7head's Avatar
Default Re: Lowering spring and shocks or coil-overs????? (fcardoso)
here my theroy about lowering car around 500 bucks
for performance---->Eibach Pro kit(1.5inch drop), is not a slamming your car but it corner better and feel better than stock. wont rub what so ever even with 17's.
the spring rates is all fixed. So is like a plug and play.
For eibach prokit, you dont need a camber kit(anything less than 1.5).
Just install it and set the alignment.
I have my eibach for two month now, it. I have 17's also
as well as 2002 coupe.
I still have my stock shock on, I am waiting for them to blow..which will take more than 2-3 years I bet.
About coilover...dont even touch those ebay 100 buck sh_t..they are junk.
Been there done that.
Get tein if you have cash to flow.
Old Oct 28, 2002 | 09:12 PM
accordblk's Avatar
Default Re: Lowering spring and shocks or coil-overs????? (iam7head)
THANX FOR THE INFO'S...
one more question...
is "ground control" coilover any good?? for my accord??
[Modified by 02accord2dr, 6:15 AM 10/29/2002]
cmiller219
Aug 22, 2007 10:20 AM
Sterndotstern
46
Nov 9, 2005 11:44 AM
crxdriver89
Sep 26, 2004 08:56 PM
etnavyman
Apr 8, 2004 09:18 AM
drunknmunkypow
Sep 15, 2003 01:34 AM
