Integra sway bar mounts
Been searching for a dang good while now and have seen alot of threads and write ups but haven't been able to find any part numbers or a place to purchase the integra sway bar mounts. I bought a 14mm sway bar off an integra for 5 bucks and will be installing it on my 94 four door civic and just need the mounts to get it on the car. Thanks for any help guys
And there's no where I can just buy the OEM mounts? I've read up on this sway bar amd other sway bars and read up don't need the subframe brace unless ur bar is over 20mm?
Found this do u think the ones here would work?
http://www.hondaautomotiveparts.com/...REAR+LOWER+ARM
Okay I guess I'm breaking down and buying a subframe brace kit now last question, will the OEM D brackets for the front sway bar fit the rear? Buddy a few towns over said he might have some but they're for the front. If not I noticed energy suspension sells some universal ones but there's two different ones I dk I they'll hold the same bushings or not
You just need the OEM Integra subframe brackets. they can be found at any Acura dealer. For a stock bar you do not need a whole subframe brace. Part#'s 28-29 and 30 in the diagram that you found. But I would make sure that you buy them for the Integra. the bolt spacing will vary depending on the size of the OEM sway bar.
MeanstreakCivic
10
Mar 13, 2008 10:30 AM
117
12
Apr 12, 2006 03:38 AM
