front sway bar 98 gsr
ok i already have a comptech rear tie/sway bar so i don't want a set(front/rear). Is neuspeed good for a front sway bar. what size as in ??mm should i get i dunno which kit to use i think it is a bar and new bushings for it. also any harm done to car when using a beefier front sway bar. trying to get the car to level out when turning a bit more at high speed.
What purpose do you have with these bars? I see you are riding on 18" so auto-x will not give you the best benefit unless switching to a low-profile stance.
most people don't upgrade their fronts, cuz going with a thicker back is good enough. The fronts are already beefy enough. try shock upgrade.
[Modified by John-GSR, 10:22 PM 10/28/2002]
i am 1.3 inch dropped with eibach's and agx kyb struts. so i thought that the sway bar's work with each other. wow the front is already 24mm?
Just Wondering~
tweek_boii
19
Nov 13, 2009 06:31 AM
gakkuken
21
May 23, 2003 02:29 PM
