D15B7 parts: Complete AC / 5 Speed conversion / Emissions / Exhaust / Cat / LOOK
DON'T BE SHY WITH OFFERS, BUT BE REASONABLE.
D15B7 intake manifold with all sensors attached, includes oem airbox/resonator, fuel rail/injectors, throttle body, wire harness, thermostat housing/thermostat etc - SOLD
5-speed transmission NO GRINDS/POP OUTS/ETC with master/slave cylinder/all hard-lines/hardware/shift linkage and axles/flywheel/clutch/toque mount/manual cluster/ECU/Rear mount & bracket/majority of necessary hardware - PERFECT FOR A 5 SPEED CONVERSION (just need pedal assembly) - SOLD
Exhaust manifold with o2 sensor - SOLD
OEM Civic DX hatchback exhaust - $100
Civic DX catalytic converter - $80
Stock motor mounts - passenger/driver/rear GOOD SHAPE - $20
100% COMPLETE AC SYSTEM condensor/lines/harness/relays/compressor/evaporator/etc EVERYTHING NEEDED! Just add R134a! Includes compressor front torque mount, tensioner pulley/mount and the belt that could use a replacement but can be used - SOLD
Alternator includes belt and bracket/hardware - $20
Distributor with wires and brackets etc - SOLD
Stock civic rear LCA (pair) - $20
Stock civic rear drums with ebrake cables and brake lines (pair) - $20
Stock civic springs/KYB GR-2 NO top hats (x4) - $80
Stock civic SOHC axles (pair) - $20
Complete EG SRS system including harness, driver airbag (wheel included) and everything needed to get it working properly, the only thing missing is the cover for the passenger side airbag. - $80
OEM 13/16 Master Cylinder - $10
