H22a Oil Filter
Old Dec 30, 2013 | 11:30 AM
vCarNage's Avatar
Default H22a Oil Filter
What kind of filter should be put on my H22A? i got my oil changed and I think they just put a normal Civic filter on it which made my cars oil pressure spike (im guessing). Either way, looking to buy filters in bulk for future changes. Help?
Old Dec 30, 2013 | 11:36 AM
95Sedan's Avatar
Default Re: H22a Oil Filter
I used the same filter as the one for my d15b7 (Bought a case)
are you sure the oil pressure spike wasnt caused my oil change not being done in a long time
higher viscus oil ( I believe ) meaning fresh/thicker oil builds pressure or additives. it's not a bad thing. Aslong as your not leaking I doubt our h22s are capable of blowing any filter out so you shouldn't need anything special.
JuggerNaut-CTR's Avatar
Ummmm....a oem honda filter.
Old Dec 30, 2013 | 12:19 PM
vCarNage's Avatar
No i had the oil change done at 5k from the last one.
Old Dec 30, 2013 | 12:20 PM
vCarNage's Avatar
I know oem is the best to go but what size. ive heard you can put an s2k filter on it, but i was wondering if there is any specific filter that i could put on it. I.E. would a H22A4 filter be the same ect.ect.
Old Dec 30, 2013 | 12:40 PM
B_Swapped93's Avatar
They usually have a book at parts store listing all the models compatible with "X model filter" just get the proper once according to the manufacturer. And how do you know your oil pressure spiked what makes you think that if you don't have a proper gauge hooked up ?.
Old Dec 30, 2013 | 12:57 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Filters for H22s and D series are the same. Honda uses the PLM-A01 filter for everything except the S2000, NSX(?), and Insight.
Old Dec 30, 2013 | 12:58 PM
B serious's Avatar
You can substitute a genuine Honda brand (PCX) S2000 filter if you want better filtration.
Your oil pressure most likely went up because they over filled it...or because the oil is thicker than what you had before. Also, since all H22s on earth burn oil, you probably had very little left at the end of your 5k mile interval....unless you've been topping it off.
Old Dec 30, 2013 | 02:09 PM
vCarNage's Avatar
Mine doesnt burn oil at all
Old Dec 30, 2013 | 03:09 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
If you want one of the best standard oil filters on the Market I'd suggest Napa Gold. They are not cheap but are made by Wix and Wix makes some of the best oil filters out there. Don't do the Napa regular it has to be Gold to get the top notch oil filter.
Whatever you do, stay away from the FRAM orange can of death.
I enjoy the best construction and extra filtration of Napa Golds for my D15B7 motor. This filter can go 10,000 Kilometers safely between changes even though I only run 7500 myself.
They cost me 11 dollars a pop here in BC Canada at my local Napa Store.
Old Dec 31, 2013 | 06:31 AM
integra_101's Avatar
Ive been told by a good friend and a guy who has owned a h22 for 20 years.
WIX is the only way to go. And I just got 2 today. one to use, and one to cut open. they are 10x better than fram and OEM honda.
Old Dec 31, 2013 | 06:33 AM
Old Dec 31, 2013 | 06:35 AM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
Wix or Nappa gold brand,same thing, nothing else, stay away from the orange **** can of doom
Old Dec 31, 2013 | 06:50 AM
what about mobil1?
Old Dec 31, 2013 | 08:32 AM
117's Avatar
117
I use the oversized Wix filter on my track car. IIRC, the PN is 51344 whereas the OEM replacement is 51334.
Old Dec 31, 2013 | 11:52 AM
Honda doesnt make filters, they have their name on them, also if you try to get the really good JDM filters, there is a big difference, the USDM part number will be substituted, they only get the good stuff over in Japan.
Old Jan 1, 2014 | 08:12 AM
vCarNage's Avatar
Would you know or have a link to any websites to purchase jdm ones?
Old Jan 1, 2014 | 09:16 AM
probably one of the direct importers. I think they got the hamp filters, I cant remember
Old Jan 1, 2014 | 11:36 AM
lol JDM filter y0
..... they're the same
Old Jan 1, 2014 | 08:05 PM
Yuyodrift91's Avatar
Unless you want to pay ridiculous amounts for legit JDM Honda filters, then a top of the line filter from your average auto parts store will suffice.
Old Jan 2, 2014 | 06:16 AM
there is no such thing as a jdm oil filter. the ones at honda in north america are the same.
i work at honda
Old Jan 2, 2014 | 09:40 AM
i work at honda
actually they arent, there are different filters for the domestic market and the japanese market, the S2000 guys found this out years ago, there have been many filter threads where they have been cut apart and shown to be different, I'm not saying to buy one of them, Wix is fine, but there is a big difference
Old Jan 2, 2014 | 09:43 AM
i work at honda
if you order the JDM ones from Honda the part numbers are substituted for the USDM ones, no one is saying they are worth buying, I put wix on everything I own, but there is a difference.
Old Jan 2, 2014 | 09:49 AM
I dont know if they have changed it in the past few years, but the OEM filters sold here were made by fram at one point, or technically allied signal since they make fram, the filters put on these cars in Japan were Hamp filters
Old Jan 2, 2014 | 05:13 PM
the only ones that are different are the s2k ones.
