Transmission & Drivetrain Gearboxes, Differentials, Clutches
1990 acura integra ls 5spd
Old Dec 29, 2013 | 07:33 PM
sleeper_'s Avatar
Default 1990 acura integra ls 5spd
*trans/sloppy shifter*
I can thumb through all gears just fine...but when I shift into 3rd it actually goes into 1st, 5th into 3rd, and reverse is 4th...rebuild? Totally crap linkage? No clue.. Anyone
Old Dec 30, 2013 | 03:33 AM
m4xwellmurd3r's Avatar
Sounds like sloppy linkage to me
Old Dec 30, 2013 | 03:29 PM
sleeper_'s Avatar
Default Re: 1990 acura integra ls 5spd
Well I should replace the linkage anyways...if its the prob I'll let you know
Old Dec 31, 2013 | 02:29 AM
I just thought of something else. Is there a lot of side to side shifter movement while you have it in gear? If its nice like it should be, take a look at your shift stabalizer bar bushings that mount the shifter end to the body (not the transmission end) also make sure thr linkage isnt bent. You could have something messed up where the shifter is hitting the hole that it goes through in the tunnel
If you have lots of side to side play while in gear then its most likely the shift linkage joint is shot
bleedblue94
20
Dec 6, 2008 04:50 PM
BB1LOViN
Jul 11, 2008 02:28 AM
rwlangdale
Feb 12, 2008 11:15 AM
tomy_r
Dec 8, 2005 10:15 PM
88EFhatch
14
Jun 8, 2005 06:11 PM
