Boost R with Hondata need your help please come in
i'll have drag kit within 2 month and i saw a group buy in best buy section for hondata ecu, i know i need that ecu for better hp increase when i have turbo,
but the thing is i dunno anything about this ecu, if i have a 2001 type-r (that's gonna be turbo soon around 8 psi) what kinda ecu i need ?? s100 or s200 ? with boost option? and what else do i need.
thanks
thanks
If you go hondata you need the following:
OBDI ecu chipped for hondata (most go with p28, p72)
OBDI conversion harness
Hondata S100, or S200, or etc. with boost option
Somone who has the burning rom software to tune it
Tuning with wideband o2 or dyno
and to find a good tuner is the key rite?
I have seen very very godo results with a certain crx here (my bro's) that underwent a test 7psi boost config & hondata. Currently he's totally rebuilding the engine properly - resleeving the engine, rods, cams, pistons etc to take extra boost.
I have the s200 unit here in my itr as well, tho I have not had a chance to get it onto the dyno yet to tune it properly, so I am back to using the standard odbii ecu. What i got was the s200 with data logging, and the odbi ecu chipped for hondata & converted to plug right in so no harness / extra cables needed.
The s100 as I understand is an cheaper option without the ability to upgrade - you buy that option, cant add to it or something. I am not a hondata expert, but better take yourself off to the hondata forums and maybe ask there for a black & white answer.
I would be interested however in your experiences in getting the system tuned & how its going / working. Im sure my bro would also be a valuable source of infor for you.
drift2004
Jul 13, 2006 08:34 AM
Diego Boost
Feb 3, 2003 02:29 PM
