92 accord no crank at start
Old Dec 29, 2013 | 03:39 PM
EJ8GSR's Avatar
Default 92 accord no crank at start
Hello everyone,
I just bought this car...been running like a champ starting fine and driving perfectly untill the other day. I woke up and went to go get gas and after I filled up it wouldnt start, so I bump started it and continued to drive around all day. That same day it started no problem so I thought nothing of it (silly me). The next day the same problem. No start. Bump start and I went about my day but it only started normally twice. That same day when im driving around the city I noticed the battery light would come on and off at times. Only a few times that night. Then today it would not start at all. Seemed like whatever the issue is it got progressively worse. I had the battery checked at autozone and it was bad so then the guy tried to give me a jump and same result...no crank. Ive noticed the starter has some dings on it probably from the previous owner tapping on it to try and start it. I checked the battery terminals they are clean and tight and no fuses blown. Im thinking starter. Any help is appreciated.
Old Dec 29, 2013 | 04:48 PM
The_Cyphor's Avatar
Default Re: 92 accord no crank at start
bump start = jump start?
Old Dec 29, 2013 | 05:27 PM
EJ8GSR's Avatar
Jump start=jumper cables and another car
Bump start=rolling the car with the key on and in first and releasing the clutch to start the car.
Old Dec 29, 2013 | 05:31 PM
EJ8GSR's Avatar
I just went tk oreillys and had my battery tested for the 2nd time today and it tested good...also my alternator tested good.
Old Dec 30, 2013 | 07:46 AM
cschlick's Avatar
check starter and connection. also check clutch start safety switch
dthor68
Honda CR-V & Element
May 4, 2018 10:33 AM
Matt S.
Jan 31, 2016 11:24 AM
allsho
Aug 5, 2008 04:30 PM
alainarcand
Jan 4, 2006 08:12 AM
Jet Black
Sep 10, 2003 07:07 PM
