Which direction to diagnose fault
Old Dec 29, 2013 | 05:15 AM
afnan's Avatar
Default Which direction to diagnose fault
Long story: when car moves from stand still sometime it bogs.sometime on full throttle it feels like it is lagging fuel.won't pick up speed
If car is off for approximately hour, I have to wait some seconds so that fuel pressure gets and it starts with half self. I can hear fuel pump when I turn the switch on it goes like eeeeeeeee and after fw seconds uuunnnnnnnn. When the sound changes then it start instantly
My fuel pump is powered by external relay. The voltages when switch is turned on is 11.6 volts and after dew seconds it drops to 9v.
I do not have fuel pressure gauge but I tested by blocking the fuel pipe with thumb.it takes some force to block fuel but I can stop it with switch on.
I suspect
fuel pump voltage regulator for waiting to fill pressure
Distributor rotor and cap for sputtering at low rpm
subie22
Oct 7, 2009 01:09 PM
zccr-xsi
Mar 29, 2008 04:15 AM
iNetForce
Nov 13, 2005 08:27 PM
ef8 h0!
Oct 3, 2005 05:32 PM
VNTEC
Jul 6, 2004 06:45 AM
